lights and instrument panel flickering and shutting off
my 2002 450 es foreman is acting up .the lights and dash light, nuetral, reverse, gear indicater lights all flash sometimrs . seems like it does it when the fan is trying to kick on. i was out riding it and it flased and the engine quit and everything went dead for about a minute then it came back on and the fan kicked on and the light flashed again. does anyone have any ideas as to what the problem could be thanks
wow that's gonna be a tough one. I would check connectors for corrosion, check all ground wires on the frame and engine. Also load test the battery and check the charging voltage. Bad batteries and faulty charging systems can cause some wierd things.
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
