2004 Warrior
Old Aug 30, 2006 | 09:29 PM
bighweel366's Avatar
Default 2004 Warrior
Hi, i Have a 2004 warrior 350cc. The bolt that is connected to the transmission and the shaft for reverse has fallen out. I put a new one in and it is tight but when i pull the lever (to get it into reverse) the bolt just turns inside of its nut instead of moving whatever it has to inside the tranny. Do i need a special bolt or can i use the one i Have somewhow? Thanx in advance
-Tim
Old Aug 30, 2006 | 09:30 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
loctite it.. and get it tight as hell( i imagine you are talknig about the bolt in the linkage)
Old Aug 30, 2006 | 09:31 PM
GraphiteDak's Avatar
I'd remove the nuit and move the shifter by hand to make sure it is still connected in the tranny.
These things are a biatch to shift sometimes, so you will KNOW if it is moving something inside.
Make sure it is adjusted to move it ENOUGH to get it all the way into reverse.
Other than that, I have never had to mess with that yet.
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
