Yamaha Blaster Oil???
Old Sep 1, 2006 | 08:35 PM
bristowboy's Avatar
Default Yamaha Blaster Oil???
I know I have to mix the gas and oil, because I DONT TRUST THE MIXER..... BUTTTTTTTT what I need to know, is do I have to put any other oil in the engine? like for the gear box and the crankshaft or does the oil in the gas lubricate it? I know a weedeater doesnt take any extra oil than what the gas has to have in it, but Idk about a blaster...
AND what is the gas-oil mixture ratio? 32:1? or what? lemme know, thanks!!!
Eric
Old Sep 1, 2006 | 10:31 PM
recon99's Avatar
it has oil for the transmission and clutch, under normal operation you don't have to add any, but it should be changed occasionally. You can use oil for 4 stroke atvs and motorcycles, just don't use regular motor oil or gear oil.
Old Sep 1, 2006 | 11:28 PM
JLsparky7's Avatar
What he said. Mix your gas at 32:1 you can do 40:1 with good oil. Some banshee guys even run 80:1 [img]i/expressions/face-icon-small-blush.gif[/img]
Old Sep 2, 2006 | 12:49 AM
bristowboy's Avatar
80-1?????? NOT ME! haha.... ill go 32:1.... maybe 40:1 when i get it broke in... BRAND NEW wiseco piston..96 bucks! and I checked the front sprocket, it has 13 teeth, is that stock?
and where exactly do I put the oil in for the gear box? there is one place on the motor that I can see, and I thought it was for the mixer???
Old Sep 2, 2006 | 05:08 AM
JLsparky7's Avatar
The tranny oil goes in the black cap right next to the kick started. The oil tank (where the mix oil goes) is located under the seat next to were the tool holding compartment is. It might not be there on your quad if someone removed it.
Old Sep 2, 2006 | 11:39 PM
Boomer2's Avatar
Premix your oil and gas according to the oil manufacturers specifications.
Sep 17, 2015 03:06 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
