Yamaha Blaster Oil???
I know I have to mix the gas and oil, because I DONT TRUST THE MIXER..... BUTTTTTTTT what I need to know, is do I have to put any other oil in the engine? like for the gear box and the crankshaft or does the oil in the gas lubricate it? I know a weedeater doesnt take any extra oil than what the gas has to have in it, but Idk about a blaster...
AND what is the gas-oil mixture ratio? 32:1? or what? lemme know, thanks!!!
Eric
Eric
Originally posted by: recon99
it has oil for the transmission and clutch, under normal operation you don't have to add any, but it should be changed occasionally. You can use oil for 4 stroke atvs and motorcycles, just don't use regular motor oil or gear oil.
80-1?????? NOT ME! haha.... ill go 32:1.... maybe 40:1 when i get it broke in... BRAND NEW wiseco piston..96 bucks! and I checked the front sprocket, it has 13 teeth, is that stock?
and where exactly do I put the oil in for the gear box? there is one place on the motor that I can see, and I thought it was for the mixer???
