Yet Another Clutch cover problem
Old Sep 5, 2006 | 01:51 PM
Entomber's Avatar
Default Yet Another Clutch cover problem
I have slaved over this thing for hours. I cannot get this cover off. I read others had the same problem but the answer was never very clear. I have removed the cover a few times but since my clutch was acting up (When you let off the clutch lever it wouldn't fully go back to it's disengaged state). I'm ready to cut the damn thing off. Any ideas?
Old Sep 5, 2006 | 02:21 PM
ScoobyDFW's Avatar
if the teeth on the arm broke from stiff clutch springs, the broken pieces can jam the arm peventing it from rotating when the cover is pulled. work the arm free as you work the cover off.
Old Sep 6, 2006 | 01:28 AM
Sandragggen's Avatar
Mine did the same thing this past weekend. I couldn't get the clutch shaft to turn to take off cover. Channel locks and a good stiff turn while pulling on cover worked for me.
Old Sep 6, 2006 | 11:13 PM
Entomber's Avatar
Since the clutch cover is damaged.. I used a pair of vice grips and kept turning the clutch arm. Well it turns out the 3rd tooth on the clutch hub itself is broken (the teeth on the clutch cover shaft looks like they have thier share of wear as well).
What causes this? Clutch springs? This bike has a set of Pami springs and has been ridden really hard in drag racing and MX. Now to replace the darn thing. Wonder how much work is it to replace. Thanks for the input guys. It's always great to get info on here.
coolguy420
Jul 10, 2015 01:17 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Sjrpp
Jul 5, 2015 09:04 PM
ranvette
Jul 4, 2015 06:13 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
