upgrade '06' 700 tire and rims
Old Sep 12, 2006 | 09:16 AM
Hardwater's Avatar
Default upgrade '06' 700 tire and rims
Just joined this forum but looking to upgrade my stock 700 EFI Camo Sportsman. They have the not so plesent rims from the factory (steel) and I am looking to upgrade them. I was wanting to go to a larger size but not to compromise the function or performance of the machine. I am not looking for swampers because this machine primary use is for running around the farm and hunting. I will keep the stock for plowing and ice fishing. Any experience or help will be appreciated.
Thanks
Old Sep 12, 2006 | 03:51 PM
Fireslayer's Avatar
Welcome aboard Hardwater, Sorry no one has responded yet. I'm not as up on your question as some others on here but I will pitch in anyways. I own an 06 700efi with the factory aluminum wheels. I can't vouch for the aftermarket aluminum wheels but I do know that there was a thread on here a short while back where a fellow was having problems stripping wheel studs after switching from factory steel wheels to the aluminum ones because the wheel studs were too short. These can be changed though. If you do a search and type in wheel, stripped or studs, I sure you can find some good info about this. I'm just not sure if the studs have to be changed to run aftermarket aluminum wheels or not. Hopefully someone else will enlighten us on this. You can reply to your own thread and just type in the word "bump" which will move your thread back to the top of the list where it might be more likely that it will get responded to sooner. Good luck.
Old Sep 12, 2006 | 04:02 PM
colt2245p's Avatar
MAXXIX BIG HORN RADIALS!!!!!!!!
Old Sep 12, 2006 | 07:12 PM
Fireslayer's Avatar
Hardwater, I have some other threads going about tires right now. You can check out the info that 's coming up on them to maybe give you some idea on what to look for.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
fd24
Jan 16, 2019 08:59 AM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
