LT80 hard start
Old Sep 12, 2006 | 05:50 PM
Dilwert's Avatar
Default LT80 hard start
Hello to everyone. I am new to this website. I joined cause i found it to be very halpful and have some great members.
I have a Suzuki LT80 that isn't starting. I can hear the starter relay clicking when I press the start button but the starter isn't engaging. The starter isn't stuck on the flywheel cause I loosen it up and tapped it with a hammer. The motor isn't locked up cause i pushed the piston down with a screwdriver from the spark plug hole. I have disconnected the wire from the relay and traced it back to the starter. I noticed it has negative current. Is this correct ? Shouldn't it be a positive current?
Old Sep 12, 2006 | 06:20 PM
Hymis's Avatar
Make sure the stater reset button is pressed under the right rear fender. I had the same problem. I cleaned the gunk out of the carb and that did it. Good luck.
Old Sep 12, 2006 | 07:21 PM
Dilwert's Avatar
I don't see a button under the right rear fender. I have a 95 model. Is it suppose to have that?
Old Sep 13, 2006 | 01:25 PM
LT80's Avatar
LT80 Expert
I had a new 95 model,I don't think the 95's have it.
It IS a positive charge that should be going to the starter.
I'll go read your hot wire thread now. [img]i/expressions/face-icon-small-smile.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
yagerzzz
Jun 24, 2015 07:45 AM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
