wisconsin ride
i mfrom oshkosh and ride all over the state sounds like fun those rally are alot of fun try the one in hurley over memorial day weekend they also do a pumpkin run that is the weekend of oct 7,8
where are you in wisconsin? monkey butt is on sunday the 17th wich has mud pit, grass drags atv pull off road course wich is always a great day hope ya have fun
so big dog talked to you their what do you recomend for a chain ? do you think the larger front sprocket will put less stress on chain? also i think if i had 4wd working i could of run close to him that second run he bogged alittle but i dont think those tracks touched the mud in the first run he flew. maybe next time you will have to run!!!
I think you have enough power on that little 440. I would not change the gear ratio in the back. I am not sure how you would change the front to match. If you ever need a hand wrenching on the polaris let me know.
i was only going to put the 13 tooth sprocket on the front and leave the back at 32 the ratio from front drive to rear would be off but not powered by the trans and only use the 4x4 in mud or deep snow i like the 32 tooth on the rear axle for the ground clearence but i would have to put a 38 on to keep same ratio i have right now ? can always use help wrenching we will have to get toegther and do that or ride some time never rode through the mud with a harley next to me what do you think on the sprocket or should i put a 12 on and not the 13
