Warn Plow / Winch hook up question
Old Sep 13, 2006 | 04:22 AM
Scott3710's Avatar
Default Warn Plow / Winch hook up question
I have a Kawasaki Prairie 3604x4 and I purchased a warn winch and plow. In the instruction is does not say anything about connecting the winch cable to plow push tube assembly. From what I see it looks like I have to hook it in the center hole, but the hole is very small. Do I have to buy some type of hook to connect winch cable to the push tube or am I just missing something?
Thanks for any help,
Scott
Old Sep 13, 2006 | 02:04 PM
alwaysride's Avatar
you can buy a quick conector with is a oval type piece of metal that has a opening in the middle were you put that through the hole on the plade and on the end of the winch cable. You can also use the heady duty type of climbing connectors. Take your hook of the end of your winch and put it through there and then connect it to the hole in the plow.
Old Sep 13, 2006 | 11:45 PM
Scott3710's Avatar
Cool thats what I was thinking, but wasnt sure if there was a special type connection for this particular setup.. Thanks for the advice!
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Gtsordo
Jul 22, 2015 01:27 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
