LT80 wires get hot
Old Sep 13, 2006 | 12:51 PM
Dilwert's Avatar
Default LT80 wires get hot
i am troubleshooting a '95 Suzuki LT80. The starter is not spinning properly. It barley spins and acts like the battery is dead. The battery is fully charged and has a reading of 13.2 v ( 11-12 v under a load). I try to start it but the relay just clicks. I bypass the relay by touching both wires but is seems to heat up the wires real quick. It does turn over a few times and then stops. I have to disconnect the wires cause they get real hot. I pulled the spark plug out and try to crank it and it cranks easily but dies quick. Anyone have a clue to what is happening?
Old Sep 13, 2006 | 01:15 PM
Hymis's Avatar
I think being that its 11 years old you may need to replace the starter. I installed a pull start on ours, this helps trouble shoot and its well worth the $ 90.00 a dealership charges for them.
Old Sep 13, 2006 | 01:26 PM
LT80's Avatar
LT80 Expert
Ditto. :0
Old Sep 13, 2006 | 02:33 PM
Dilwert's Avatar
just wondering what sure the compression read on an LT80 ?
Old Sep 14, 2006 | 11:07 AM
LT80's Avatar
LT80 Expert
120-130.
Less indicates some wear but can get by. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 14, 2006 | 11:26 AM
Dilwert's Avatar
Well I took the started off yesterday and took it to a local Suzuki dealer. They bench tested the starter and told me that the starter was bad. It drags and pulls too much current. They say the starter is probably grounding out inside. I also found out that your no suppose to jump start it from a car with the motor running. They say that the car, while running, will send too much current to the ATV and this might have cause the death of the starter. I am looking for a replacement now. Thanks for the help.
Dil
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
400H0
10
Aug 20, 2015 07:34 PM
frostphase
Aug 19, 2015 07:11 PM
Bergmann
Aug 13, 2015 03:51 PM
DeFox500
Jul 26, 2015 06:32 PM
