rip in sidewall, the tire is garbage
Old Sep 13, 2006 | 08:45 PM
magnumLover's Avatar
Default rip in sidewall, the tire is garbage
i baught my tire to my dealer today and i showed him my tire, he says the tire is garbage, brand new bearclaw, has a rip in the side wall and its garbage? pisses me right off.
Old Sep 13, 2006 | 09:00 PM
spyder6's Avatar
sidewall tears arnt repairable. it cuts the belting. sorry about your luck.
Old Sep 13, 2006 | 09:13 PM
ncriderforks's Avatar
What cut the sidewall? Do you have aluminum wheels? Is it a straight cut?
Old Sep 13, 2006 | 09:14 PM
2manytoys said something about cutting out the bad and putting in new rubber, is this possible, from what iv heard 2manytoys is quite wise.
Old Sep 13, 2006 | 09:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i have 2 rips in my xtr's i that i fiex w/ no problems yet and 1 in my wifes pxt's. plugged and slimmed them both. there a way to put a hot patch on the inside to seal the side wall and you could always put a tube in it as well i beleave. just an idear.
Old Sep 13, 2006 | 11:19 PM
ftwflh's Avatar
I have ran up to 3 plugs in one hole on the sidewall with no problem.AS expensive as tires are try putting some plugs in it and then slime it.If that dont work put a tire patch on it and run a tube.Beats a new tire.
Old Sep 14, 2006 | 01:19 AM
i think im guna do the patch in the inside, do u do it just like a bycicle tire? or those plugs [ my rip is a v shape about half inch across, ALL the dealers say its garbage, u all give me so much hope!]
for the plugs do you just bend them inhalf and stick them in with that tool they come with??? and how hard is it to take the tire off the rim?
thanks alot!
Simon
Old Sep 14, 2006 | 01:26 AM
could one of u guys post a pic of ur plugged / slimed fix, thanks
Old Sep 14, 2006 | 02:03 AM
DennisC's Avatar
Been there done that. Alot of it matters what its for. I've plugged several tires for utility quads. I sliced a brand new Holeshot on my very first ride out on my Banshee. I cut about a 3 inch slice in the sidewall and tried everything to fix it, from slime, to patched inside and out, to plugs. I even tried to run a tube in the tire, I got the kind of tube with a threaded valve stem with a nut on it. The first time I got the Banshee in the sand and opened it up it completely pulled the valve stem out of the tube. I spent more money out of being stuborn on fixing that tire than my next new one cost. Good Luck Dennis
Old Sep 14, 2006 | 09:22 AM
colt2245p's Avatar
i have repaired many sidewall cuts. it is not permanent and must be rebone occasionally but it saves a new tire. first i take a dremmel or die grinder and smooth the area of the slice rough it up and take any lettering down to the carcass level. then get a good thick patch and glue it on and let it set for a while and it holds for some time it just depends on how much abuse it gets. when it starts leaking again repeat above procedure.
