clutch problem on 200s
Old Sep 15, 2006 | 03:33 PM
69chevyman's Avatar
Default clutch problem on 200s
i am having problems with the clutch slipping when in 2nd gear and up when i give it 1/4 throttle. i put a new centrifigul clutch on it last year, does that mean it is allready wore out or is the other clutch plates wore out.
Old Sep 15, 2006 | 05:00 PM
HondaAtcRoxz's Avatar
Is it only slipping in second gear and no other gear???
Old Sep 15, 2006 | 09:05 PM
69chevyman's Avatar
2 3 4 5 gears 1st a little
Old Sep 15, 2006 | 10:38 PM
were the plates goin bad when you changed the clutches? Are you sure you put the clutches on correctly? I would pull it back apart and check it out to see if anything looks wrong...
Old Sep 15, 2006 | 10:43 PM
lawnboymelvin's Avatar
i have the same problem as yours on my 200m and i think its is the friction disks on the manual clutch.
Old Sep 16, 2006 | 11:52 AM
69chevyman's Avatar
when i changed the centrifigul clutch i did not check the clutch plates, im sure they need changing. (22 years old) every thing has worked good until lately.
Old Sep 24, 2006 | 12:31 PM
69chevyman's Avatar
what about synthetic blend oil, good or bad.
Old Sep 24, 2006 | 05:18 PM
I hear they are bad for them... I think it makes the clutches go bad faster. There was another thread on here where they taked about what type to use...
skinnyr6
Aug 25, 2023 02:18 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
honda71
Jul 8, 2015 02:13 AM
