Scrambler Questions...
Old Sep 17, 2006 | 09:42 AM
NYC's Avatar
NYC
Default Scrambler Questions...
Hey Fellas
I got a few questions if someone can help me out... Also Thanks in advance...
1st off I was planing on getting this from Rocky Mountain ATV.
K & N Oil Filter - 2004 Polaris SCRAMBLER 500 (Or should I get standard Oil Filter? Also do I use standard Oil, Should I use synthetic?)
K & N Air Filter - 2004 Polaris SCRAMBLER 500
K & N Jet Kit - 2004 Polaris SCRAMBLER 500 (Do I need this if I change the Air Filter Or if I get an Exhaust?)
Motor Power Standard Battery - 2004 Polaris SCRAMBLER 500 (This was the Cheap one-Motor Power Standard Battery/ Or should I get YUASA Standard Battery any differences?)
Outerwears Pre Filter For K&N Air Filter - 2004 Polaris SCRAMBLER 500
What Exhaust should I look into? I definitely don't want it to wake the dead.
Also what Clutch kit is best?
Where could I get a Hitch for my Scrambler?
What brand of Some Decent Handguards should I go with?
Again Thanks for the Help!!!
Old Sep 17, 2006 | 10:37 AM
ftwflh's Avatar
If you wanbt my advise on your 500 Scrambler(most of it is from experince)
Dont waist your money on a K&N oil filter.Polaris or Emgo are just fine.
Stay with the K&N air filter w/outerwears
Get a good battry not a cheap one
On the pipe find a White Bros Eseries if you can or go with the Aaen plated w/spark arrestor
Wait until you have a pipe before putting in a jet kit (you will have to change the jetter after the pipe.
On clutching if you want good smooth power got with a Dalton black/white primary spring and either a Aaen blue or HPD violet secondary set at 2-2 with stock weights.Or if you want a harsher power range go with a Aaen green primary spring,10-56 weights and either one of the secondary springs.This aggresive set up can be hard to ride in tight technical conditions.
On the handgaurds and hitch look on Ebay for them.
Old Sep 17, 2006 | 03:09 PM
NYC's Avatar
NYC
Hey ftwflh,
Thanks Alot
I want to start working on her, & don't want to waste time & Money on the wrong parts.
I definitely appreciate the Help!!!
~So should I go w/ this battery from Rocky Moutain-> YUASA Standard Battery. Or go pick 1 up @ Walmart?
Old Sep 17, 2006 | 03:17 PM
kfxandahemi's Avatar
I would get a wix # 51358 and some royal purple or amsoil motor oil. Wix filters are as good as they get and I have had very good luck with Royal Purple, and many people here use amsoil.
Here is a link to a wix filter look up, may check and see if I told you the right #.
Wix filter lookup
Old Sep 17, 2006 | 03:19 PM
One more thing, I dont know about Polaris Clutches, but I love my Dalton Kit on my KFX. I think dalton has the best clutch kits.
Old Sep 17, 2006 | 10:46 PM
ftwflh's Avatar
Dalton make great clutch parts[img]i/expressions/face-icon-small-wink.gif[/img]
Old Sep 17, 2006 | 11:20 PM
dirtsnow's Avatar
also uni makes good air filters too, if u want to check them out, they have a pre-filter
sleeve that goes over the main filter, they have worked great for me & I also use the
amsoil 0-40 4 stroke oil & wix oil filter.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
bmark0610
Sep 7, 2015 09:42 PM
