sportsman 500 engine compression
Old Sep 22, 2006 | 08:57 PM
f250's Avatar
Default sportsman 500 engine compression
Can anyone tell me what the engine compression should be for a 1999 Sportsman 500?
Old Sep 22, 2006 | 09:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
guessing at least 100 psi
Old Sep 22, 2006 | 10:30 PM
cornbread2's Avatar
Why do you ask?
What sort of problems are you having?
Old Sep 22, 2006 | 11:15 PM
f250's Avatar
Original problem was no spark. Ohm meter indicated the stator was the problem. Trying to pull the flywheel per the repair manual, had the puller on and when i turned the large center bolt on the puller the engine would rotate, after about 1/2 trun in got hard to turn and when I beared down on it something popped, I thought it was the flywheel breaking loose...but it wasn't... after that it seemed somewhat easier to rotate the engine. I put a comperssion gauge on it an only reads approximately 25psi???? Pulled the vavle/rocker cover off the rocker arms are both moving the springs look OK, the cam chain is OK. I do not know how much compression it had before, but it was running fine up until it stop firing the plug. The recoil starter/flywheel/stator area was full of water.
Old Sep 23, 2006 | 12:51 AM
MaineMudder3's Avatar
The sportsman 500 motor has an auto-decomp so putting it on a compression gauge it will only read 20-35psi.
Old Sep 23, 2006 | 10:25 AM
f250's Avatar
Thanks, I am very happy to hear that. So how do I check the true compression? Another question, how do I lock the flywheel to keep it from turning so i can pull it off?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
neilbedwell
Nov 10, 2018 11:02 AM
joshuafromny
Jun 22, 2015 05:30 PM
scaldwellk
Jun 19, 2015 05:08 PM
Schneider
Jun 4, 2015 11:37 AM
