Blaster won't start
Old Sep 23, 2006 | 09:04 PM
Storj's Avatar
Default Blaster won't start
My blaster has been sitting for a few weeks and now it wont start. Its got spark, compression, clear jets, clean carb, good reeds, clean air filter. It seems to like kick back when you kick it i dont know what could be causing this. I also just did the top end not to long ago and it ran fine until it sat. Any help would be appreacited.
Old Sep 23, 2006 | 09:18 PM
Boomer2's Avatar
Maybe your getting to much fuel. Try and start it and see what plug looks like afterwords. The float might be sticking or fuel valve worn.
Old Sep 23, 2006 | 10:59 PM
Storj's Avatar
I dont think so. When i pulled the plug it was clean maybe even a little to clean like it was running lean. But i dont think i was running it lean i use the standard 30:1 premix.
Old Sep 23, 2006 | 11:25 PM
ds650ctracing's Avatar
I think you are flooding the cylinder somehow, Are you sure the plug is getting a spark ?
Old Sep 23, 2006 | 11:30 PM
Storj's Avatar
I tested the to see if it had spark and it did.
Old Sep 24, 2006 | 01:54 AM
From what information you posted I would draw the conlusion that you may have a carburetion issue of one of the following : too much gas getting into the cylinder, not enough gas getting into the cylinder, bad gas in the float bowl, bad gas in the tank, float sticking, Im sure there are other possibilties also but I myself would look into these first. hope to help. You might could try to pull start it but use caution and be safe[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 24, 2006 | 02:03 AM
JLsparky7's Avatar
Clean your carbs, use fresh gas.
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
