kodiak
Old Sep 24, 2006 | 08:26 PM
billytoyota's Avatar
Default kodiak
I have a 02 Yamaha Kodiak 400 4x4, in the winter I have a problem with the shifter freezing so I cant shift till it is fully warmed up, any suggestions
Old Sep 24, 2006 | 09:38 PM
ATV_MAN's Avatar
Default kodiak
Spray some lube on all the joints, it has to be sticking somehwere where it's close to the engine/trans, I don't think it would be your shifter lever assembly, has to be the linkages since they are close to heat.
Old Sep 24, 2006 | 10:08 PM
squeege's Avatar
Default kodiak
I think it's cause it idles high until it is warm
.....you can't shift unless it is at idle
Old Sep 24, 2006 | 10:54 PM
Default kodiak
thanks for reply, I dont think it has to do with idle cause I cant shift it when its not running either
must be frozen joints
thanks again
bill
Old Sep 25, 2006 | 05:28 PM
FRIGGS's Avatar
Default kodiak
You probably have some water and crap inside your shifter housing. Their is a drain tube which runs down from the bottom of this housing. At the end of this drain tube their is a plug which you have to remove and let the water/crap drain out. Leave this plug out for a few days to dry then spray some lube inside the shifter.
If this dosen't work you might have a problem with your shifting linkage, possibly might need new connectors or just adjustment.
Hope this helps.....Friggs
02 Kodiak
Old Sep 25, 2006 | 09:33 PM
Default kodiak
thank you, I appreciate it
bill
Old Nov 29, 2006 | 01:30 AM
willieb76's Avatar
Default kodiak
move to florida there is plenty of room for another Kodiak dude here
RedRancher
Oct 15, 2020 01:45 PM
YankeeRebel
Oct 6, 2015 06:44 AM
RedRancher
Aug 10, 2015 01:28 PM
Jul 28, 2015 12:12 PM
RedRancher
Jul 10, 2015 06:36 PM
