Need help agian on my 660 raptor 2001
OK i was out at big rock this weekend everything was great for the first like 3 hours on then it just went to hell when i pulled the clutch in and put it in gear it felt like it went into geat but when i would release the clutch and give it gas it would want to go but it never did like i could feel it like move forward a bit but it never actually went anywhere do you no what might be wrong????? And do you think this problem would be the same reason that when i go to fire up my raptor now it sound like my gears are grinding and sounds horrible.
thanks
New to the raptors
thanks
New to the raptors
OK i was out at big rock this weekend everything was great for the first like 3 hours on then it just went to hell when i pulled the clutch in and put it in gear it felt like it went into geat but when i would release the clutch and give it gas it would want to go but it never did like i could feel it like move forward a bit but it never actually went anywhere. And do you think this problem would be the same reason that when i go to fire up my raptor now it sound like my gears are grinding and sounds horrible
Well there are a few things it could be when you pulled in your clutch and now it will not go..You could have broke a clutch spring..Or you could have broke a clutch fiber...If i was you i would order a Barnett dirtdigger clutch setup..It comes with all new fibers and springs..will run you $120.00 Bucks.....BUT If its not your clutchs im sorry to say..Your tranny has went out..And that is going to cost..So i would get the LA starter Clutch..(you need that no matter what) And the Barnett Dirt digger clutches...Im sorry for the bad news..Iv just been though it..
