2000 Grizzly 600 brake light not working?
Old Sep 25, 2006 | 11:31 AM
alegend's Avatar
Default 2000 Grizzly 600 brake light not working?
It might seem like a dumb question but my friend has the above quad and the brake light never worked. He bought the quad used with low hours. Checked bulb ect... any idaes, has anyone has a similiar problem. This light is supposed to work, correct?
Old Sep 25, 2006 | 02:07 PM
hondabuster's Avatar
Doesnt work with either front or rear brake?
Check the fuses,and make sure all the wires are still clean, dry and hooked up, for the brake light.
Does the tail light work?
Old Sep 25, 2006 | 10:05 PM
alegend's Avatar
Brake light doesn't work with either brake, tail light does work.....
Old Sep 25, 2006 | 10:35 PM
moses155's Avatar
Well, make sure the 00 grizzly even has a brake light cause i know the warrior 350 does not have one in 2000. But if it does have a brake light, then i would check your ground, make sure the brake light is grounded. You'll also see a little brake light switch over by the brake pedal, check that out too, make sure the pedal is activating the swith properly. moses155
Old Sep 27, 2006 | 07:17 PM
alegend's Avatar
Thats what my original question was does the Grizzly 600 come with a working taillight?
Old Sep 27, 2006 | 07:18 PM
alegend's Avatar
Actually I meant to say brake light?
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
BGC
Utility ATVs
Oct 7, 2015 11:50 PM
BGC
2) Chassis problems..
Jun 10, 2015 06:07 PM
kylevipond
Apr 21, 2000 08:08 PM
