dragging brakes
Old Sep 26, 2006 | 11:26 PM
UltimateAussie's Avatar
Default dragging brakes
i just put new rotors and pads on my warrior and now i think they are dragging as the rotor gets really hot, how do i fix this.
Old Sep 27, 2006 | 12:20 AM
recon99's Avatar
I can't think of any reason the brake pads would be dragging unless your calipers were bad. I'd let it go a little while, and see if it stops. The pads and rotor might just be a little too thick together and the caliper won't slide open far enough.
Old Sep 27, 2006 | 05:49 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
It could be a bad caliper . Did you do any adjustments to the master cylinder linkage? if you adjust the linkage and the piston in the master cylinder cannot come all of the way back up it will not release the pressure resulting in a dragging brake or total locking up of the brakes.
Old Sep 27, 2006 | 04:48 PM
recon99's Avatar
Is it all the brakes, or just the rear? Because the rear could be dragging due to the parking brake.
Old Sep 27, 2006 | 04:49 PM
bombrider04's Avatar
that or the rotor could be coming look from the hub or not on straight and cuasing it to rub against the brake pads
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
