Long travel suspension
Old Sep 29, 2006 | 11:39 AM
warwgn's Avatar
Default Long travel suspension
anybody know anymore info about this set up??
http://wideopenracing.easyphpbb.com/viewtopic.php?t=79
link button dont work and I am to lazy to re post the pics.
looks like a good set up though, just looking for more info or comments.
Old Sep 29, 2006 | 03:37 PM
JLsparky7's Avatar
The crossover setup looks like its custom made, cause its not painted just bare metal. Which it says someone made it in the forum. Which setup are you referring to?
Old Oct 2, 2006 | 10:18 AM
warwgn's Avatar
the bare metal stuff. I want to get more real travel for desert racing, i would love to get 20" of travel and still keep it under 50" wide. It does not seem possible with traditional doubble wishbone set up so I am looking into options, and just wanted some more input or ideas.
Old Oct 2, 2006 | 03:16 PM
warwgn's Avatar
nobody on here knows about suspension???
Old Oct 2, 2006 | 09:04 PM
TPR's Avatar
TPR
The Champ
That setup, both front and rear is real tricky. If you plan to race you need to be sure that such modifications, or anything differing from a stock configuration is allowed. That setup would not pass in a production scenario where a gusseted frame shee with arms would.
Dean was being innovative for sure. I did see it race and the rear shock went up like a pogo stick after 30 miles. He still races it in SCORE races though.
There has also been a 250 that had a rising rate, pushrod/bellcrank a-arm setup too. It allowed the shocks to be mounted between the frame rails and use of shorter shocks.
Also, do a search for the W-Tec Eraser quad...totally different ,leading arm design completely without a-arms. I have questions about druability, but again, original.
Truth be told, with a little work you can get a solid 16" of travel in the front. I've seen 21" cycled through on a rear suspension setup. Problem you run into is you may end up with too much ride height, even with the best sag control type shocks, and some travel may be useless because you would end up hitting the frame.
Take you time and good luck.
TPR
Old Jul 26, 2007 | 05:42 AM
velocyraptor's Avatar
kinda old thread but look at this website www.xtravelsuspension.com their frames sell for 8grand and heres deans # 619-952-4922
Old Jul 26, 2007 | 06:01 AM
they will do it for any sportquad nd they'll give you a rolling chassis ready to have all the parts bolted on
pgamboa
Dec 24, 2023 11:52 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
awer1968
Sep 8, 2015 11:02 AM
chewy78
Sep 8, 2015 10:37 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
