warrior bore
Old Dec 5, 2000 | 11:13 PM
gnx87's Avatar
I bought the JE 12:1 high comp 2mm bore piston, does anyone know the exact bore in thousands of an inch? what are the ring gap specs?
thanks,
Old Dec 6, 2000 | 12:20 AM
99WarMachine's Avatar
Bore: 3.268"
Piston Ring Endgap
Top: 0.008 - 0.016
Second: 0.008 - 0.016
Oil Ring: 0.012 - 0.036
Old Dec 6, 2000 | 07:22 AM
gnx87's Avatar
thanks,
A 2mm over bore on the stock sleeve is 0.080" bore right? which would take me from 3.268" to 3.348" Any help would be appreciated i have to give it to my machine shop guy and tell him how far to bore it.
Also has anyone had trouble with their warrior since boring it out to .080" ? I have heard that they get really hot and dont disapate the heat
Old Dec 8, 2000 | 01:26 AM
Fourplay's Avatar
If you have to tell the machine shop guy the finish size mabye you should find another machine shop (one that specializes in motor rebuilds) The piston should have come with specs,... piston to cyl. clearance and what part of piston to measure, etc. Give the piston and spec sheet to the person doing the work and they will measure the piston, then bore & hone the cyl. accordingly.
Barnsnelbon
Sep 27, 2015 03:07 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
