my 250sx
Old Dec 6, 2000 | 05:38 AM
puddding's Avatar
i have brought a 250sx reciently and have finally got around to giving it some TLC....even though she is aready REAL straight!
it is leaking oil out of the front of the motor, and is looking like it needs a new head gasket....am i heading in the right direction....it is coming from the head....has anyone else experienced this with these motors
also what type and size cam chain does it take?
and is adjusting the clutch similar to the honda 300 4x4....ie....loosen lock nut, loosen it, tighten screw till resistance then let off 1/4 turn, then tighten lock nut?
plus i have a worn bushe in the bottom of the rear shock, can i get away with spinning up a bush in the lathe to fit instead....any suggestions
cheers.....this is the first atc i have owned, it now lives with my 250x
am very impressed with the way it goes!....
for a farm bike (reason i brought it).....it flat out hauls!
Old Dec 14, 2000 | 07:38 PM
valerius's Avatar
I think you've made a very good choice. I too have a 1985 250sx. I'm the second owner, bought in '87. I've owned this trike for a loooooong time. I can attest that it has been to hell and back. Ripped apart twice and put bakc together. After sitting for 6 yrs, in the elements, in pieces, same fluids it was easily brought back to life. I am currently restoring it to as new condition as possible with a few additions to make it a little better. This trike is a tank!! I have never been left stranded or had engine problems.
To answer your questions;
1. never had this problem, but sounds like you are heading in the right track. i suggest cleaning the engine of all the oil, dirt and such. then ride for a while and keep an eye on the area that you think the oil is coming from.
2. get a repair manual, I've got two of them. i picked mine up at Honda. If you can't find one I'll sell you one of mine.
3. adjusting the clutch is exactly as you describe. I would still get the manual and double check.
4. I don't see why making your own bushing wouldn't work.
Enjoy the ATC.
Old Dec 16, 2000 | 06:35 AM
puddding's Avatar
thanks for the reply.....
i am going through my 250sx.....basically tidying it up at the moment
shes a hummer of a bike!
on the gravel.....theres not a lot between her and my 250x!
Alans250sx
ATC 3-Wheelers
Nov 21, 2007 04:08 PM
haywoodjalikme
ATC 3-Wheelers
Apr 17, 2006 01:00 AM
HondaCrazy85
ATC 3-Wheelers
Oct 16, 2004 09:52 PM
BigRed1985
ATC 3-Wheelers
Jul 27, 2004 05:21 AM
HondaCrazy85
ATC 3-Wheelers
Jun 19, 2004 09:41 PM
