Banshee Cylinder Smoking
I would lay money you got a crank seal leaking oil out of your case on the side that is blowing smoke..Just take both your covers off and replace both...Its not hard to do..just take your time and do it right...I went though the same prob with a buddies banshee..easy fix..Its just the seal..dont mess with the bearings...
If it were the left outer seal, I would think you'd have lean condition due to that side sucking in air and you'd see no smoke. If the right side smokes, that crank seal would suck in transmission oil in additon to air.
A couple of questions:
Is bike running on both cylinders? If not change spark plug. Is by chance the pilot jet in the carbs plugged, if not are the carbs in sync. Like RP YFZ said I dought it is a crank seal. Try above and see what happens.
If it is a crank seal, the case must be split. the seals have a lip that fits into the grooves in the case. Pounding the seal in is not the correct way of putting in seals.
Chris
Chris
Chris
Chris
Improper float setting or a bad float valve can cause one cylinder to smoke more than the other
[i]Originally posted by: drwindmillBanshee is definately running on both cylinders, and has a ton of power. Just the one side smokes way more.
jrooker6
Apr 23, 2016 07:36 PM
