03 grizz throttle cable
Old Oct 5, 2006 | 07:49 PM
jarhead6's Avatar
Default 03 grizz throttle cable
riding last week and my throttle stuck wide open i assume the cable broke because it want retact. i took the bolts out of the heat sheild but how do you get the one behind the carb.anyone else had this problem i need to know this so i can change the cable.( or someone tell me an easy way to change the throttle cable
Old Oct 8, 2006 | 11:16 AM
witti's Avatar
http://216.37.204.206/alba/Yamaha_OE...=13&A=268&B=11
Here is a link with the parts list of a carb. To replace the cable you need to pull the cover off the right side of the carb (#25). I think I had to pivot the carb a little to get at all of the screws.
Old Oct 8, 2006 | 08:21 PM
jarhead6's Avatar
thanks for the imput. after removing the breather from the carb, i was able to move the carb enough to get the bolt out of the heat sheild. after that i aws able to get to the cable thanks
Cummins Driver
Sep 11, 2019 01:22 PM
GregM
Mar 6, 2018 06:53 AM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 23, 2015 02:21 PM
toonces
Jul 16, 2015 03:19 PM
