ETON NXL50 LIGHTNING
I have a eton 50 that the fan got trashed and they continued to ride it. It got hot enough to melt the engine plastic. i plained the head and installed a new head gasket because it was leaking. it was starting good but no good after 1/2 throttle. Now it doesnt even want to start. it has 115 pounds of conpression. Maybe the electric choke or the rings? dont know which way to go? JOE
only a 115 pounds it stll could start but depends on the rings if you can spray either to try to get started sometimes that work if the choke is not working if that dosnt work take the jug off ckeck it out but your compression is low it should be 165-185
Elkaholic
Sep 6, 2015 02:44 PM
