Kodiak 450 speed limiter problem
Old Oct 8, 2006 | 03:06 PM
power123456789's Avatar
Default Kodiak 450 speed limiter problem
I just bought a new kodiak 450 and when i put it into differential lock it will always go the same speed as if the overide butten was always pushed in. As of what i have heard it should keep me from going over a certain speed unless you push an hold the overide button. I just dont know why the speed limiter is working. Does anybody have any suggestions?
Old Oct 8, 2006 | 03:29 PM
wille's Avatar
do you mean when you engage diff. lock your machine is not limited to any speed?
Old Oct 8, 2006 | 03:33 PM
yes when i engage the differential it will go at any speed. Do you think there is something wrong with it cause i was going 25 mph without pressing the overide butten its like the butten does nothing
squeege's Avatar
HUH?
Old Oct 8, 2006 | 03:37 PM
when i engage it into differential lock it will go at any speed. isnt it suppose to keep it from hitting a high speed when the overide button int pressed down. And then if you want it to go faster in differential lock your suppose to press the overide button and hold it, but it doesnt do that it just acts like the button is always pressed down and goes at any speed in deffirential lock
Old Oct 8, 2006 | 03:39 PM
wille's Avatar
Is the bike brand new from the dealer?
Old Oct 8, 2006 | 03:40 PM
yes just bought it is a 2007
Old Oct 8, 2006 | 03:43 PM
wille's Avatar
maybee the diff. button is not working so its not actually going into lock. in any event i would return to the dealer.
Old Oct 8, 2006 | 03:47 PM
it going into lock it because it gets to the point where it is impossible to turn or is hard so i know its going into lock. is there a suggestion on what i could try to do . i am just trying to get the speed limiter to work. at what speed is it limited too in diff. lock. because i only tryed 25 mph.
Old Oct 8, 2006 | 03:51 PM
wille's Avatar
im not sure about mph but i think mine was 25 or 30 km/h, your problem might not be such a bad thing though it saves you from having to hold that button down, which can be difficult sometimes when in deep mud.
