trouble removing wheel from ATV
Old Oct 12, 2006 | 12:12 PM
frase's Avatar
Default trouble removing wheel from ATV
I recently purchased a set of XTR's and had them installed on cheap after market steel rims. I wish to remove the wheels and tires and it took me over an hour just to get one off. The next one is going to be a similar problem. The problem lies with the fact that the hole size in the rim is EXACTLY the same size as the wheel bolt and also, the hole is not tapered to accomodate the tapered nut. The only way I could get the first one off was to hit the rear of the wheel near the bolt at the back with an iron bar and large hammer. Even then, it only moved very fractionally. I then had to turn the tire to the next bolt and do the same procedure again. Any ideas on how to get them off easier?? Also, once I do get them off (if ever) could I drill or file the holes a little large remebering that they are not countersunk? Also, could I countersink the holes myself a little? Any ideas appreciated. Thanks.
Old Oct 12, 2006 | 10:14 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Common rookie mistake....did it once myself! You should have turned the nut around, flat side in, and put a washer under it.
GregM
Jul 29, 2015 09:41 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Jul 21, 2015 03:03 PM
Desimation2k8
Jul 17, 2015 12:37 AM
