1982 185 3-wheeler - no spark
Old Oct 13, 2006 | 08:07 AM
Smitty12345's Avatar
Default 1982 185 3-wheeler - no spark
Producing no spark. What do I check first? Someone said that the pulse generator could be ohmed to see if it is good/ What Ohm value would I need to look for....Any suggestions will be appreciated.
Old Oct 13, 2006 | 11:13 AM
HondaMechanic's Avatar
none
Old Oct 14, 2006 | 11:45 PM
Tried another spark generator and electronic ignition module/box and still have no spark, Now I guess I am down to thinking it is the magneto. Any suggestions or do you agree or disagree? Thanks
Old Feb 11, 2007 | 07:49 PM
fcukmitch's Avatar
i have no spark too. i have no clue what is wrong? maybe you got yours fixed and could help me with mine?
Old Feb 11, 2007 | 11:29 PM
Mine was actually two things. The main spark producing coil under the flywheel(the black one not the copper one) had a broken wire. I replaced that and still no spark so I replaced the pulse generator(pickup) under the cover where the points would normally be...and it went to work. I was told that the black coil under the flywheel should OHM out at about 245 OHMS. Check by putting one tester lead to the red wire and one test lead to ground. Clymers says that the pulse generator OHM value for a 200E is not applicable. Hope some of this helps a little.
Old Feb 12, 2007 | 09:51 AM
fcukmitch's Avatar
my bike works if i jumpstart it thou? so im confused. and i think i have a bad killswitch connection is what i think i have. i want to know how to bypass it? any help?
Old Feb 12, 2007 | 06:58 PM
I don't think it would crank and run if the kill switch is bad. What about your battery? Is the battery fully charged. If weak, trying to start takes most of the power and leaves not enough for the rest of the circuit.
Old Feb 12, 2007 | 07:10 PM
fcukmitch's Avatar
i aint got a battery in it. but when i do and i try to start it with electric start theres no spark but when i wiggle the button there is spark. and plus i was using a 1150 ca battery.
whats ohm
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
