Need a rear caliper
Old Oct 16, 2006 | 03:28 PM
stugots's Avatar
Default Need a rear caliper
Does anyone have a extra rear caliper they don't need?
On my last ride I was trying my new trinity stage 4 pipe and it bottomed out and smashed the brake line clamp and locked up the rear brake.
I was on a long dune run and when I stopped the rear was smoking hot. It ended up warping and melting my caliper and pads.
I am still trying to find out why it hit the swing arm. Have any of you had this problem?
When I called Trinity the just played the I don't know game. Then when I asked if the have any mounting instruction for me they told me not for that pipe because they don't sell many of them. WTF<[img]i/expressions/face-icon-small-shocked.gif[/img].
So I have my new roter and pads but I cant find a caliper.
Thanks
Old Oct 16, 2006 | 08:17 PM
bombrider04's Avatar
Check in the what's in your garage thread or try ebay for parts...Did the brake line just rip altogether from the rear caliper because if you look where the foot brake is and follow the brake line there is a brakcet where the brakline rests and it may have come loose from there and pulled on the brake line causing fluid loss and air in the lines and when you pressed on the brake it may have seized up and not been able to release pressure or something hit it from the ground.
Old Oct 16, 2006 | 11:13 PM
stugots's Avatar
No the actual pipe bottomed out and smashed the clap holding the brake line where it is mounted on the swing arm.
That caused the fluid to close the caliper and then not release.
do the front brakes interchange with the rear?
Old Oct 17, 2006 | 01:05 PM
They are prob really close as long as the brake line is the same size and the mountin holes are the same I wouldn't see why it wouldn't work they are the same single piston caliper so
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
