Easier Starting / Compression Release
Old Dec 7, 2000 | 10:44 AM
DrRod's Avatar
Greetings,
I recall a post regarding pull starting that mentioned some sort of compression release valve that helps the engine turn-over easier. Can anyone tell me what this is and where its located on the 450ES? Also, would this help the engine turn-over easier and start better in winter?
Old Dec 7, 2000 | 09:00 PM
3o0eXpAuL's Avatar
i dunno i remeber there was a lever on the top front part of my engine on my bayou 220 to start it easy?
Old Dec 7, 2000 | 10:47 PM
BigRed450's Avatar
DrRod:
I believe the compression release is now automatic on all machines. Older machines had a lever at the top of the head.
What I would do is if you suspect your machine may be hard to start because of the cold, turn the engine over a couple of times with the pull start to loosen up the engine before trying the electric start.
Old Dec 8, 2000 | 01:53 PM
Zorro's Avatar
I'd say it's automatic...except on the 400YZF (three levers/buttons to push in order to get running). Anyway, with electric starter, you won't need it...and it probably automatic (or it doesn't work).
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
joshuafromny
Jun 22, 2015 05:30 PM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
