High Comp. Piston
Old Oct 18, 2006 | 09:53 PM
strings's Avatar
Default High Comp. Piston
I'm am tring to find a high(er) compression piston for a 360 prairie (stock is 8:3) and I would like to bump it up to (9:1). The 300 Prairie used a 9:1 piston and I think the 400 did to. ANY HELP OR IDEAS WOULD BE AWSOME.
Strings
2004 Kawasaki 360 Prairie 4X4
Full Skid Plates
Mud-Lites
Moose Hand Guards
Speedo
EPI Black Secondary
1999 Honda 300EX
2004 Arctic Cat 250 4X4
1972 Ford Bronco
1993 Chevy 1 Ton
Detroit Diesel
Old Oct 19, 2006 | 12:45 PM
tibs's Avatar
try "WISCO ".
i put wisco .5mm over piston & rings in mine with no problem.
flatter piston with deeper pockets for valves,in case you go with an after market cam.
however i beleave the 360 jugs are NIKASIL coated so you would not beable to just bore them out a bigger size without recoating them first, wich can be rather expensive.
L.A. SLEEVE sells a sleeve for the 360 for about $70.00.
another suggestion might be to check out a site like maxrpms.com and look into a big bore kit has everything you need.
good luck.................
Old Oct 19, 2006 | 10:09 PM
strings's Avatar
Boy thanks I'll try your suggestions. By the way what is Nikasil and what does it do?
Strings
Full Skid Plates
Mud-Lites
Moose Hand Guards
Speedo
EPI Black Secondary
1999 Honda 300EX
1972 Ford Bronco
1993 Chevy 1 Ton
Detroit Diesel
Old Oct 23, 2006 | 08:59 AM
tibs's Avatar
I'm by far an expert and sure I'll be corrected by the end of this thread.
NIKASIL is a nickel cadmium coating that is on pourris metals such as aluminum sleeves, witch seals the walls for compression.
mostly on two strokes and smaller cc 4 wheelers because of higher rpm ( racing etc.) because aluminum is lighter and displaces heat faster then iron.
compared to cast iron sleeves which are in MOST 4 strokes do not require to be coated.
again I'm not sure what type of sleeve you have, the easiest way to find this out is to disassemble your engine and using a magnet (old speaker magnet works well) hold it to your sleeve, if it sticks its iron, if it does not then it's aluminum.
another way is to look at the inside walls, NIKASIL will look like shiny almost polished but to many factors can fall in to play and make you think otherwise IE; worn ,contaminated, etc.
the best way is to talk to a machinist and perhaps the manufacture.
good luck........
I ENCOURAGE ANY BODY TO PLEASE CORRECT ME IF I'M WRONG SO "STRINGS" DOESNT GET LED ASTRAY...
Old Oct 23, 2006 | 05:47 PM
Hayashi's Avatar
Your 360 has the electro-fusion (or splattered) walled cylinder that can't be bored out.
exmotocrosser
Sep 13, 2019 06:12 AM
r1pilot83
Sep 27, 2015 07:38 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
