Need help with warrior smoking
Old Oct 21, 2006 | 02:36 AM
beresford's Avatar
Default Need help with warrior smoking
Exhaust valve was stuck open the other the day, i took the head off and cleaned out some carbon build up on the head and valve. Valve works fine now but now i have exessive smoke and it's blowing some oil out the exhaust. any help as to what it could be. it was running fine till the exhaust got stuck open.
Old Oct 21, 2006 | 09:25 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
it's blowing oil out the back??? as in you can see it.. or only if you put something in front of the exhaust?
Old Oct 21, 2006 | 09:32 AM
beresford's Avatar
if you place your palm behind the exhaust you see the oil on your palm.
Old Oct 21, 2006 | 01:05 PM
recon99's Avatar
you probably damaged a valve seal or valve guide when you had it apart
Old Oct 25, 2006 | 01:08 AM
scottd's Avatar
Or the rings are shot. Excessive carbon on the valves was probably caused by deposits from previous oil consumption. Do a leakdown test to determine. I say it's the rings.
Old Oct 25, 2006 | 01:20 AM
DriverDoyle's Avatar
Thats right..I would lay money that you need to change your valve seals and guides on both valve..just dont do the one that is bad..there cheep to do..and you can do it yourself..So change both..and i bet you your prob will be gone..
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
