400ex mild buildup
Old Oct 22, 2006 | 10:27 PM
JimmyHoffa's Avatar
Default 400ex mild buildup
Hey. Nothin' hard. I'm just sellin' my 300ex for a 400ex, which I plan to mainly make to look cool and handle extra nice, and also do mild engine work. I've solidly decided to go with a normal bore (.020, .040 whatever I need to get the taper out) Wiseco 11:1, for mild performance and reasonable reliability. I am going to invest in an LRD pro4 full system and UNI filter. I'm unsure on the cam though. I have some ideas and understand the basic science of camshafts, but if anyone has had good luck with a certian cam in this situation, or knows a lot of stuff, let me know. Feel free to delve into obscenely technical discussions. I've done a fair amount of engine work and am competent.
Old Oct 23, 2006 | 03:40 PM
asfasasu3's Avatar
If your looking for the cam specs and all, I'd sudjest going to their web sites. Everything is there that your asking for. Try looking for Hotcams (camshafts of coarse) Megacams, Webb cams. I found mine on e-bay and got a good deal on it. (after I figured out what I wanted) Plus the Hotcams don't have to have different valvesprings and such. That helps the pocket quite abit.
I have a Hotcams stage 2 and it is allright. I think it would run alot better if it had a higher compression, but I don't plan on tearing into the motor until I have to. It revs alot quicker than the stocker, and it seems to pull harder every where in the rpm range. I was hoping for alot more than what it gave me, but over all, it made a nice difference.
Old Oct 23, 2006 | 07:48 PM
JimmyHoffa's Avatar
nice. anybody know about the stage 1? I dig hardcore low end power, and it seems that the only diff was that the stage 1 focused more on the lower end of the RPM range.
Old Oct 23, 2006 | 11:26 PM
rapittrx450r's Avatar
Port it your self .. yes hot cam stage 2 and go 12:1 not 11:1.. or have some one port it for you ,with all that it will screamm oh dont forget the valve spring kit . you can still run pump gas 91 oct .
Old Oct 25, 2006 | 09:38 PM
JimmyHoffa's Avatar
pump gas at 12:1?! maybe you're not using the right head gasket :-/
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
