Trail Boss 330 Gearcase noise
Old Oct 24, 2006 | 05:52 PM
zippy03's Avatar
Default Trail Boss 330 Gearcase noise
Hi;
Have 03 330 TB and am getting a clicking noise in the gearcase. At first I thought it was a sprocket, and or chain, but have replaced the sprockets and now the dealer just put on a new chain and it is still there. They think it might be the internal chain in the trans as it only happens in forward and under load. ANy one ever experience anything like this and how hard is it to remove the gearcase. Trying to save some $$$ by doing the time consuming labor myself. Power and lower end torque seems perfect.
thanks
Old Oct 28, 2006 | 03:56 PM
dirtsnow's Avatar
all the clicking noises that I have had have always been with the 520 drive
chain. It is best to put a new chain & sprockets on together at the same
time(at least the front sprocket for sure) so they wear in together. If u
did not ride much with the new sprockets & old chain, it should still be all
right, it will just just take a little longer to wear in with the new chain. put
lots of lube on it at first, that should help. also have u ever changed the
oil in the gear case? could be water or bad oil in there.
Old Oct 30, 2006 | 09:21 AM
zippy03's Avatar
Hey dirtsnow, thanks for the info. I think you might have hit on it in your first part. I did change the front sprocket a few months back and when I did the noise went away for a bit, but slowly reappeared. Then I replaced the rear and somewhat of the same, but then the chain got real loose and out of adjustment. This is when I had it replaced, but the small sprocket was on there for a bit against an older chain. You are the second person that said replace all at same time for proper wear. Think I will get that done first and see where it leaves me. Will update asap.
Thanks
Old Nov 1, 2006 | 07:07 PM
zippy03's Avatar
Hey thanks dirtsnow, that was the problem. Replaced the front sprocket and the noise is gone. Just replaced the 22 inch rears with 25 inch mudlites for better traction and more ground clearance. Cant wait now to go this weekend and test it.
Thanks
Old Nov 1, 2006 | 07:26 PM
dirtsnow's Avatar
glad I could help!! keep some good atv/dirtbike lube on the chain that will
help repell the water, dirt & sand. That will help make your chain & sprockets
last longer, use Like bellray etc.
Old Nov 2, 2006 | 08:53 PM
zippy03's Avatar
Have been using Castrol Chain lube which is suppose to be great for them. And I use it regularly, but I think my problems started when I did not keep up on having the chain tight. Oh well live, learn and then pay [img]i/expressions/face-icon-small-blush.gif[/img]. We got 3 years and about 3500 kilometers out of that set, hopefully longer this round.
Thanks
Old Nov 4, 2006 | 01:51 PM
campNride's Avatar
I had the same problem with my trailboss 330. I tried to go cheap when I busted up the front sprocket and only replaced the sprocket with the intention to replace the chain on the next payday. Well I forgot all about it until I was at a jamboree and was a very long ways from the truck. It continued to work but the noise was ugly sounding. I replaced both chain and sprocket and magically it went away. Didn't think they could make that much noise.
Shainasmash
May 8, 2017 06:38 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
