1998 kx 125 gas ratio????
Old Oct 26, 2006 | 04:42 PM
trx4501991's Avatar
Default 1998 kx 125 gas ratio????
everyones been telling me im putting in the wrong ratio in my kx, wuts it suposed to be
Old Oct 26, 2006 | 05:05 PM
Hayashi's Avatar
If your engine is not seized and if it is not fouling the plug nor gives too much oil smoke, whatever ratio you are using must be OK. It should be around 32:1 on your KX if you are using a mineral based oil. If you are using synthetic based, it could be higher/leaner. I've seen a claim as high as 100:1 on Motul brand.
Old Oct 26, 2006 | 07:53 PM
holeshotz8436's Avatar
40:1 is a safe and good all around ratio for mineral or synthetic oil.....im my 96 kx i use 40:1 amsoil dominator synthetic and in the 01 yz i run 32:1 amsoil just for a little extra oil down in the bottom end because i have alot of work done to it and dont want any failures......
Old Nov 4, 2006 | 08:10 PM
saby73's Avatar
If you bought the bike new it should have beened a sticker on the rear fender that said the mixed ratio witch is 32:1
Old Nov 5, 2006 | 08:30 PM
enFORCER's Avatar
I run 32:1 in all my 2 strokes.
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
Slagpolaris
Sep 5, 2015 09:41 PM
honda71
Jul 12, 2015 05:56 AM
