1982 185 3-wheeler - no spark
Old Oct 31, 2006 | 10:38 PM
Smitty12345's Avatar
Default 1982 185 3-wheeler - no spark
Tried another stator assembly and magneto. Still absolutely no spark. I even got brave enough to hold the plug and ground ny hand against the head and pull the rope. I disconnected the headlight from the frame since everything goes through the light..thinking if the engine switch or headlight switch was shorted out by removing the ground of the light to the frame I might get some spark..still no spark. I have tried another CDI box and coil from a running machine. Still no spark....I also tried another spark generator pickup from a running wheeler--no spark...What on eareth can it be? These things seem to have the simplest wiring of anything I have ever seen. What next? Unwrap every wire on it to see if I find a broken wire in the small bundle on the frame?? I hate to be beat by anything..I seldom fail or give up but this one has about eaten my lunch..
Old Nov 1, 2006 | 08:30 PM
Fenton88's Avatar
Hey where abouts do u live? I just sold my 185s and it didn't have any spark i got sick of wastin money on parts
Old Nov 1, 2006 | 09:34 PM
I'm in Mississippi, and I knew the guy that has always owned this one. He told me it had no spark but the price was right. He gave it to me..Bound to be a broken wire or something else simple. The electrical system is really simple and has few parts. Not anything I ever have to get going but after a while a challenge turns to a pain in the rear.
Old Nov 1, 2006 | 09:54 PM
rdeeno's Avatar
I have a 84 TRX200, which is close to the same. I have done some searches in this forum and came across a intermittent no spark that was the wiring going thru the case from the exciter coil in the alt. Also, have you check all your wiring, just ohming it out wont do, one strand of wire will ohm out good, but willnot carry a load. Disconnect all your components from your harness, rig up a fusable link, wire up a 12volt light, apply power to one end and the light to ground at the other. See how bright the light is. You could also put a volt meter across the bulb and check for voltage drop. Measure from your power source to ground first and compare it to what you get across the bulb to ground, which should be the same.
Old Nov 1, 2006 | 10:04 PM
Thanks. I plan to start unwrapping wires as soon as the weather lets me get back to working on it. I will try what you suggested. Thanks again.
Old Nov 1, 2006 | 10:21 PM
rdeeno's Avatar
While you are waiting, if you don't have one already, I would get a manual, like a Clymer for it. I have one for my old TRX 200 and it is some pretty good info in it. Got my off of fleabay. LOL
Old Nov 1, 2006 | 10:42 PM
HondaMechanic's Avatar
none
Old Nov 2, 2006 | 07:35 AM
How do I do the test you are referring to and what numbers would I be looking for? Thanks
Old Nov 2, 2006 | 02:06 PM
none
Old Nov 2, 2006 | 10:51 PM
The link did not work for some reason. Could you please send it again. That sounds like exactly what I need. Thanks
