Got a small problem again
Old Nov 2, 2006 | 08:14 PM
Tat2d's Avatar
Default Got a small problem again
Ok,as I i've said before.I bought a 2000 Trailblazer,used.Well I just got it back from the shop and it was dirty,lots of oil and stuff everywhere,so I took some degreaser and sprayed all over it and then I hosed it off.Wellthe problem is,now it won't start and when I do get it to run for a second,it backfires a few times and cuts off.Should I just let it sit for a bit and then try to start or did I really screw something up bad.
Please help!!
Thanks to everyone who is helping me,it's just that I have never owned a two stroke before so I'm learning.
Old Nov 2, 2006 | 08:24 PM
310's Avatar
310
Do you have a oil injection block off kit. It could also be that you got water in the carb.
Old Nov 2, 2006 | 08:33 PM
Tat2d's Avatar
no I don't I was going to do that but I was told I didn't need it.How do I get the carb drained.I am supposed to drain the oil out of the oil tank and mix gas and oil together he said b/c this is how I ended up rebuilding it in the first place,it failed on the guy I bought it from and it had to be rebuilt.
Old Nov 2, 2006 | 09:39 PM
ftwflh's Avatar
Let it dry real good and it should be ok.
Firefighter400
Oct 8, 2022 06:38 PM
Frisky2050
Apr 9, 2020 11:19 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 19, 2015 10:13 AM
black_thunder
Jul 9, 2015 05:58 PM
