Wolvie just cant climb a hill?
Old Nov 4, 2006 | 03:11 PM
Gus13's Avatar
Default Wolvie just cant clib a hill?
I went riding with some people today and odd thing is it cant even climb some long steep hills because it takes too long to get the rpm's to turn over. It gets to the middle of the hill and bogs out. Someone I was riding with took it to see if they could make it up and said something is definately not right. Maybe due to my K&N and snorkel removed and FMF pipe the bottom may be way to lean. I did change the main to 145. Maybe I need to go up on the smaller jets too? Any suggestions before I take it in to get worked on and spend $200+ on it.
Old Nov 4, 2006 | 03:16 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Wolvie just cant climb a hill?
u did say u had a 160compression on a stock engine.. you got soemthing wrong..
Old Nov 4, 2006 | 03:36 PM
Gus13's Avatar
Yep, 160 compression. Hmm... Any suggestions what it may be? It should climb the hills right?
Old Nov 4, 2006 | 03:41 PM
Speedy2222's Avatar
pull your plug and see what knid of condition it's in
Old Nov 6, 2006 | 11:28 AM
GlennJ's Avatar
Are you trying to go up the hill without downshifting? I find that on my machine, I have to keep the RPMs up to keep the machine moving. The Wolverine is no torque monster, so approaching a hill in a too high of a gear just doesn't work. I often find when climbing longer, steep hills, a down shift is usually in order.
dannytas
Sep 26, 2017 06:31 PM
Pgbama11
Jan 16, 2016 08:19 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Pgbama11
Sep 10, 2015 08:20 AM
