Banshee Problems
Old Nov 8, 2006 | 09:01 PM
Moter's Avatar
Default Banshee Problems
I have an 02 banshee that doesnt start. I have a brand new stator and cdi box in it. I had it at a yamaha service center and the did stuff to the carbs. The plugs are fine and any fuses i can find look ok. Im 15 yrs old and my parents wont pay for nething i have payed for all of it by myself so what do u think i should do.
Old Nov 9, 2006 | 12:10 AM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
I would check your wiring, and check your kill switch and key switch as well as the key, other wise well your are strating it try giving it a little gas. What exactly did they do to the carbs?
Old Nov 9, 2006 | 04:10 PM
Moter's Avatar
the said i neede neddle valve assemble so that all the did and cleaned them
the gas thing doesnt work because there is no spark at all i took the plugs out and grounded them and there was no spark so idk
Old Nov 10, 2006 | 02:45 AM
bombrider04's Avatar
the check to see if anything is loose wiring wise and make sure you have a ground...check the killswitch and key switch if you have a multimeter test for ohms or resistance on these things try disconnecting the 3 yellow wires that go from the rectifier to the stator and try cranking it over again if it works then you have a problem with the stator eithe not being assembled correctly or something
Old Nov 10, 2006 | 03:39 AM
JLsparky7's Avatar
Take the tors off if its not already.
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
