rubicon dynojet kit
Old Nov 12, 2006 | 12:22 PM
4x4rubicon's Avatar
Default rubicon dynojet kit
i put a new set of mud lit xtr 26' tires on and wondered if a dynojet kit will help improve throttle response and low end torque enough to even bother with it?
Old Nov 12, 2006 | 03:25 PM
Rinman's Avatar
If you were in a high elavation area I'd say yes. But if your looking for a better response clip your throttle spring. This doesn't hurt anything and really does help out throttle response. It takes about 10min. Just remove the top cap on your carb and remove the spring and cut off 10-11 coils and put the longer piece back. This is free. But if you really want more power then an HMF and filter are your best bet.
Old Nov 12, 2006 | 04:23 PM
pprince's Avatar
What is an HMF?
Why does shortening that spring help throttle response?
Old Nov 12, 2006 | 05:49 PM
Rinman's Avatar
An HMF is a exhaust pipe. Kinda like putting a flowmaster muffler on it. An HMF pipe is ungodly loud but makes alot of power on these utility quads. Shortening the carb spring basically softens it. Its a vacuum carb and with the spring shorter it allows it to rev faster. It really does make one come off the line alot faster. Its the same thing Hotrodders have been doing to vacuum secondary carbs for years.
Old Nov 12, 2006 | 06:44 PM
4x4rubicon's Avatar
The QS1 series is alot more quiet,but does it give as much H.P.?
Old Nov 12, 2006 | 10:51 PM
Rinman's Avatar
I have to go on what I read. So take it for what its worth. The HMF utillity series makes more power than any other pipe out there. I have a big gun and it made a nice increase and the noise isn't bad either. But a friends HMF really is making power. But its so loud you hate to follow behind him.
shimanok2
Jan 29, 2016 07:37 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
colt1126
Aug 18, 2015 10:38 PM
