2003 ES Sputtering After Starting
Old Nov 15, 2006 | 03:50 PM
pintail102430's Avatar
Default 2003 ES Sputtering After Starting
2003 ES 400 no problem with starting. Once it is started with choke out, it runs OK, put choke in and put in gear and then it sputters and dies. If I let it warm for a couple of minutes with choke out and then put choke in it does not die when put into gear. Once it is warm it runs good. Anybody experiencing this and how can I keep it from sputtering and be able to start and go?
Old Nov 15, 2006 | 04:05 PM
PaulH's Avatar
Assuming you have the idle speed correct... Try to richen the idle mixture screw 1/4 to 1/2 turn, set the idle speed when it warms up. The choke is there for a reason. You need to let it warm up for a minute or two before you cut loose.
Old Nov 15, 2006 | 04:37 PM
bombrider04's Avatar
yea and also make sure that your jets are kept clean along with the rest of the quad(filter,oil)
Old Nov 15, 2006 | 09:18 PM
melloyello's Avatar
Well, any engine, especially a carbureted engine should be allowed to reach operating temperature b/4 use. If the engine is cold, it will need more fuel. That's why it needs the choke on to run correctly. Once up to operating temperature you can release the choke and ride.
It does help to turn the mixture screw out 1/2 turn on almost all the Hondas straight off the floor. Just about every one of them is running just a tad too lean at idle.
Thanos
Jul 12, 2015 08:40 PM
Dakosk
Jun 6, 2015 05:37 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
