How to do a compression check and whats needed?
Old Nov 18, 2006 | 04:25 AM
JLsparky7's Avatar
Default How to do a compression check and whats needed?
Just as the title says. How do you do a compression check and what is needed. Its for a 99 blaster but is anything different for the banshee other than the 2 cylinders?
Old Nov 18, 2006 | 07:18 AM
enFORCER's Avatar
No difference, except your just checking one cylinder instead of two. Take the spark plug out, screw the gauge in and give it a few kicks.
Old Nov 18, 2006 | 03:08 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i'd also like to add... besyre ti take the plug wire off the plugs b4 starting... just so u don't start it by accident
Old Nov 19, 2006 | 08:41 PM
Nicname's Avatar
OK... Take out the sparkplug (it can't start without the plug - unless it has unreal compression...) Thread the appropriate adapter into the plug hole, attach the gauge. Hold the throttle wide-open and give it 4-5 good solid kicks, or until the gauge stops climbing...
If your gauge doesn't thread into the cylinder, have a buddy hold it over the hole firmly while you kick it...
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Dabears1983
Jun 16, 2015 12:17 PM
rapple
Jun 2, 2015 01:38 PM
