05 Grizzly 125 starter issue
Old Nov 19, 2006 | 03:31 PM
Figgers's Avatar
Default 05 Grizzly 125 starter issue
My sons 125 Grizzly's starter misses when it gets hot. After an hour or two, if he shuts it off for a short time he goes to restart it and the starter just spins and grinds, it won't make contact. I pulled the starter out and was suprised to find that the starter isn't designed to slide out and make contact with the flywheel like most do. I assume there is another gear in the case that slides to the starter. If thats in fact the case then fixing it will be a huge pain in the ***. Any thoughts? Anyone had this problem with there's? Any help would be much appreciated. Thanks in advance.
Old Apr 15, 2020 | 08:47 PM
Dirtydevildogg's Avatar
I'm having the same exact problem, were you ever able to figure it out?
Old Apr 26, 2020 | 02:32 AM
"I pulled the starter out and was suprised to find that the starter isn't designed to slide out and make contact with the flywheel like most do."
Cars yes, on motorcycles and quads, hardly ever, I think the Suzuki LT80 is the only one that does, maybe one or two Chinese kids quads.
Motorcycles and Quads usually use a one way clutch behind the flywheel. On the Yam 125 this runs dry and gets dirty. Strip it, clean it, check the springs are OK and put it back together. On most Quads, if they start slipping they are toast, but the older, three rollers with springs behind them, designs, can often be revived.
bigcam400
Jun 1, 2012 12:15 PM
slimshady75
Jul 11, 2004 07:01 PM
cwdancer
Apr 7, 2004 12:14 AM
ALABAMA200s
ATC 3-Wheelers
Nov 23, 2003 11:38 AM
RacinJason
Jan 15, 2003 09:37 PM
