Raptor 660 HELP!!!! Bogging out........................
Old Nov 22, 2006 | 03:41 AM
chuyzama's Avatar
Default Raptor 660 HELP!!!! Bogging out........................
Hi there i have a raptor 660r, the quad was running great but suddenly it started bogging out and slowing to a stop with a couple of exhaust explosions, after a few moments it goes back to normal speed and runs fine without explosions, but ig goes back to bogging out, trowing smoke and explosions.....We cleaned the carbs, adjusted valves, changed spark plug, oil...but no luck it does the same, someone told me that its the harness that the problem is electrical....They checked the motor and everything is OK....Please help[img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 22, 2006 | 07:04 PM
chuyzama's Avatar
Anyone please help........
Old Nov 22, 2006 | 07:08 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
you did a whole lotta stuff there.. But what about the source? Hows your airflter?
Old Nov 22, 2006 | 08:04 PM
chuyzama's Avatar
iI have a k&N filter but i think it sucked lot of dirt, Could this be the problem?
Old Nov 22, 2006 | 08:06 PM
chuyzama's Avatar
Also the reverse light started to light up when its bogging out but it won't actually go into reverse....Thanks
Old Nov 23, 2006 | 09:19 PM
BostonKev's Avatar
I recently had the same thing occur surprisingly right after I paid a dealer to have the carbs cleaned. I ended up replacing the float needles but what was causing the bogging and backfire was the that the dealer stripped the hex screws on the clamps the hold the carbs into the rubber intake hoses and what was happening is they were intermittnetly sucking air causing it to die and run like crap. I replaced the clamps and life is much better.
Old Nov 25, 2006 | 09:10 PM
albaraptor660's Avatar
Hello, you probably already did this but check the parking brake switch you can follow the wires down and unplug it. Also try grounding the green wire by the foot shifter it's going to a sensor and see if that helps.
Old Nov 28, 2006 | 03:15 AM
rruser's Avatar
You just found your problem. The switch that tells your CDI you are in reverse is tripping and kicking in the rev limiter. Check and or replace the reverse switch. Its located near the shifter.
Old Nov 28, 2006 | 12:03 PM
fastblaster00's Avatar
before you do anything els check your parking brake switch. since i have no parking brake on mine it does that someones. theres that little push pin thing and every once and a while it desides to be a b1tch and makes my bike idel fine, but run like @$$ when i give it gas in gear
Old Dec 12, 2010 | 10:05 AM
moutsouna's Avatar
just wanted to say thank you. i had that problem to my raptor and you solve the problem. it was the parking brake switch . thanks again .Dimitri
