Yamaha 175 2 wheeler
Old Nov 26, 2006 | 04:09 PM
Smitty12345's Avatar
Default Yamaha 175 2 wheeler
78 Yamaha 175 Enduro. went thru the carb a few months ago and rode it. ran fine...mixer pump went out years ago so the gas and oil is manually mixed. Went to crank it today and you cant turn it over with the kick starter..Took out the plug..Same thing..Suggestions..Apparently sitting for 2-3 months the rings have stuck..
Old Nov 26, 2006 | 08:41 PM
DavidLT250S's Avatar
if its stuck your going to probably need to replace the rings and hone the cylinder.
Old Nov 26, 2006 | 08:50 PM
JkAss's Avatar
You can try to pull your plug and squirt some WD40 or equvilent, let it sit than try to kickit over, Most likely will need to pull the jug to figure out if it is a top end or bottom end problem. If it kicks over with the jug off than you most likely just have to do a top end job. If it still doesn't move than rebuild time.
Old Nov 26, 2006 | 08:51 PM
I guess so..Just looking for a easy, quick fix but I have been around long enough to know there is no such thing..........@ least I'm never that lucky..
Old Nov 26, 2006 | 09:03 PM
I put Marvel Mystery oil in it today and will let it sit till tomorrow evening then try it.. Thanks
Old Nov 27, 2006 | 08:20 PM
try stove oil or desiel if that dont work, if its been sitting for only 3months i doubt its the bottom end.
Old Nov 27, 2006 | 08:48 PM
Thanks--tried it a few minutes ago and still no movement at all...
Old Nov 27, 2006 | 09:07 PM
JkAss's Avatar
Sorry to say it, but time to pull the cylinder.
Old Nov 27, 2006 | 09:24 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Try putting it in gear and rocking it back and forth.
Old Nov 27, 2006 | 10:31 PM
I tried it in gear before I put the MMO in it but I haven't tried it since. I will though.. Reckon I would have any luck with removing the side cover and trying to turn the flywheel?
