exhaust
Old Nov 30, 2006 | 10:18 PM
spursxfanx1991's Avatar
Default exhaust
I got a 300ex and i have been ridding it for about 5 weeks and 2 days ago i was ridding and the Exhaust got hot and started to melt the body but lucky i caught it i was wondering why it suddenly started getting so hot? i hadnt been ridding it long and i have been putting it through alot tougher stuff.. i was wondering if there was somthing wrong... n e help would be apriciated...thnx
Old Nov 30, 2006 | 10:48 PM
zettler450r's Avatar
Default exhaust
dont worry about it , you can get some heat shield material and put it on the plastics to prevent them from melting but I wouldnt worry about that quad getting too hot... I had an 01 300ex rode it in 115 degree AZ desert weather for hours and never had a problem
Default exhaust
other than singing the my leg hairs on the exhaust
Old Dec 1, 2006 | 11:33 AM
bombrider04's Avatar
Default exhaust
Lol...yea just pick up some of the tape and put it on the under side of the plastics to prevent the plastics from melting anymore, and then all should be good. The only way you would have a problem is if the exhaust is glowing red but it is fine if it isn't.
Old Dec 6, 2006 | 08:21 PM
Williebee's Avatar
Default exhaust
You might check the valve clearances to make sure they are within specs , if the valve clearance is ok you will be fine ! ..............williebee
Old Dec 6, 2006 | 08:47 PM
slomoe's Avatar
Default exhaust
have you done any maintenace check your air box and filter you may have a lean condition making it real hot
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
