Need help--clutch release adjustment
Replaced the shoes in the centrif. clutch and the friction clutches in the main clutch. Hadn't put oil back in it yet because oit don't seem right. I wet the friction disc with oil when I installed them...I have to hold the shifr lever down manually for it to disengage and be in neutral..Otherwise it is like it is in neutral then its not when you rock it back and forth..Do I just need to assume that with the cclutch release adjusted as the book says----do I need to assi,e it is acting weird because it has no oil in it? Do I need to just put oil and try it? Everything went back together goodand the side cover fell into place, no pressure, no bind????PLease advise....Thanks
Sep 30, 2015 01:37 AM
