Replacing inner rear CV boot on 06 700
Old Dec 3, 2006 | 04:23 PM
MNATV's Avatar
Default Replacing inner rear CV boot on 06 700
We were out for about 10 minutes when I noticed the left rear inner boot was torn. Any advice on how to replace this would be greatly appreciated.
Old Dec 9, 2006 | 06:06 PM
MNATV's Avatar
Please...never done this b4.
Old Dec 9, 2006 | 07:34 PM
ncriderforks's Avatar
You can leave the joint in or take it out. There is a snap ring inside the joint. You have to spread it apart and pull the shaft out of the joint. Put on the new boot and put the shaft back in. The snap ring will open on its on when you put the shaft back in because the shaft is tapered. Once you get the shaft back in the joint (make sure the snap ring is closed) put the boot on the joint and you are done. You will have to take the hub and wheel and all off and it makes it easier to take the sway bar loose from the a-arm so you can keep the shaft straight. Putting it in at an angle can be tough
Old Dec 9, 2006 | 07:36 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there is plenty of post on this subject if you do a search on it.
Old Dec 9, 2006 | 10:34 PM
MNATV's Avatar
Thanks nc! appreciate the help
Sandman2.0
Jul 21, 2015 09:03 AM
WilliamBos
Jul 13, 2015 02:11 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
