ITP Front Rims
Old Dec 5, 2006 | 09:26 AM
bmxatv's Avatar
Default ITP Front Rims
I just purchased a set of black T-9's with holeshots for the rear of my quad and they look awesome and hook up even better. I've looked high and low and from what I've found ITP does not make this same rim for the front in a 22x7-10 for a 400ex. I'm assuming that means it's a 10" rim correct? Can I drop to a 9" rim without making any modifications i.e. wheel spacers or anything. What should I do? I want the same setup for the front as I have in the rear (black T-9's on holeshots). Any suggestions guys? Am I even making any sense?
Old Dec 5, 2006 | 09:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
22X7-10 is a TIRE size, not a rim size. The front RIM size you want would be a 10X5 (10" in diameter and 5" wide).
It's almost a given that if they make a rear rim in black, they are going to make the fronts in black as well to match it. Check ITP's web site, and even give them a call if you have to. Also, I have found that Rocky Mountain stocks absolutely everything ITP makes, so check their catalog and give them a call. Also, you could try atvdirect.
I like the T9 rims (I run the Baja, because the regular T9's bend a lip a little to easily), because they have a greater offset (3+6) and width (9X9) than stock. This combined with wider than stock tires, makes the quad about +3" wider, for a nice increase in stability.
Old Dec 5, 2006 | 02:12 PM
bmxatv's Avatar
Thanks recon. The tires on the front are the stock ones but they're like new as I got them from a friend who recently swapped his out for Maxxis Razr's. will my 22x7-10 Tires fit that 10x5 wheel? What are some other tire sizes I could run on the front that would make stability improvements? Thanks for your help as always.
Old Dec 6, 2006 | 11:50 AM
Red Rider
22X7-10 is pretty much an industry standard front tire.
I am currently running Holeshot XC's on my bigger quads, and the new ITP TracStars on the 250's. I am so impressed with the TracStars that I am going to give them a try on the bigger bikes. I don't think they will give quite as good traction as the Holeshots, but he ride is soooooo much nicer.
Old Dec 6, 2006 | 08:32 PM
drag101's Avatar
i have the holeshots on t9 polished rims all around on my EX and love them try a 21-7-10 then will fit ur rim and holeshot makes them
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
coldnorthpol
Jul 14, 2015 11:22 PM
tporath
Jul 11, 2015 12:31 PM
