What the !@$%$% is wrong with Polaris
Old Dec 5, 2006 | 04:18 PM
KINGSCLEAR's Avatar
Default What the !@$%$% is wrong with Polaris
My father in law just bought the 06 450 sportsman, I was checking it over and discovered it still has that cheap squeeze clamp on the crankcase vent hose. I lost an engine due to this on my 04 600 miles and I know two other guys with the same problem . You would think for the price of a gear clamp they would do it from the factory. If you have a Polaris or any brand for that matter because I also seen it happen to a Honda check this out and change it. On the Polaris there are 3 rubber hoses coming out of the crank case. Two have gear clamps on them,they are fine. One has a cheap squeeze clamp on it....CHANGE THIS TO A GEAR CLAMP !!!! Do this please, what happen is the squeeze clamp can get pulled off by a branch or twig and then your bottom end will fill up with what ever your driving in mud water . It is so easy to prevent
Old Dec 5, 2006 | 04:25 PM
TLC's Avatar
TLC
Thanks I will check that out.
Old Dec 5, 2006 | 04:27 PM
KINGSCLEAR's Avatar
yes do it's a 5 min repair that can save thousands
Old Dec 5, 2006 | 04:34 PM
TLC's Avatar
TLC
HeII ,Im just finding out about the stick Stopper things also.
Old Dec 5, 2006 | 04:35 PM
KINGSCLEAR's Avatar
yes get those also I did after my first axle
Old Dec 5, 2006 | 10:14 PM
SAshton's Avatar
whats a stick stopper
Old Dec 5, 2006 | 11:41 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
I didn't know about the stick-stoppers ...so don't feel bad...........About that cheap clamp....I own two 2006 450 I will check that out!!!!THANKS.....................caper........... .
Old Dec 5, 2006 | 11:44 PM
Heh...STENDORI........You have a 450 also.....Did you change yours already.........if not here is your heads-up on the clamp!!!!!....caper.................Thanks to this post again..........
Old Dec 5, 2006 | 11:58 PM
TLC's Avatar
TLC
Read this whole thread.
http://forums.atvconnection.com/mess...did/507070.cfm
Old Dec 6, 2006 | 08:09 AM
SAshton's Avatar
cool. 55.00 for the both sets? Is that right?
